Smart Group Wallpapers
  • December 2, 2016
  • 18 views
I am trying to set a separate lock screen wallpaper and a separate home screen lock screen via two (2) separate Smart Group Device Profiles. Since you cannot specify different wallpapers for each location in the software I setup the first and cloned it. Then I changed the cloned one to set the other wallpaper, problem is that it changes the other SGP to match the one I just changed. Ending up being two of the same SGP and they are named different.
Is there an easier way or is this even possible?
Thanks.
1 reply
bentoms
Forum|alt.badge.img+35
  • December 4, 2016
@Alengygel I'd suggest an FR to split out the lock screen & wallpaper.
