One frustration I have is when I re-assign an iPAD to a new user I need to remove the configuration profile for our web filter & lock screen info, and then re-add them on the devices to have the web filter show the appropriate user, and have the device name show properly on the lock screen.
Does anyone know of a way to automate this?
IE.. I change a user, it will remove & re-add specific config profiles?
