Posted on
04-15-2015
08:38 AM
- last edited on
03-04-2025
03:45 AM
by
kh-richa_mig
I've got my DEP working a treat with Casper but I can't see how I get the scope of the prestage enrollment to automatically include any new devices. At the moment I am having to go into the scope and edit it to tick the new devices. Sure I am missing something simple!
Thanks
Solved! Go to Solution.
Posted on 04-15-2015 10:05 AM
@etippett Right next to where it says "Device" on the left hand side. When I click edit for my prestage enrollment. I'm still setting my environment up, but I would think you would have this option as well. Currently mines unchecked as I've just been doing some testing.
If you have a checkbox next to the red arrow pointing at it, that should solve your issue.
Posted on 04-15-2015 09:21 AM
Have you tried checking the checkbox that says "device" so any new devices that are for prestage enrollments are automatically selected?
Posted on 04-15-2015 09:57 AM
@fbaker Can you elaborate on the "device" checkbox or provide a screenshot? Is that located in the PreStage enrollment? I'm on Capser 9.63 and see no such thing
Posted on 04-15-2015 10:07 AM
@fbaker AH HA! Thank you. Didn't realize it only showed up in Edit mode.
Posted on 04-15-2015 10:13 AM
@etippett Glad you got it working!
Posted on 04-16-2015 05:42 AM
Thank you, didn't realise that tick box would also select future devices!
Posted on 04-16-2015 07:20 AM
While this button does let you select all, in my environment at least, it doesn't add future devices.
Posted on 08-24-2015 02:28 PM
Hello everyone, as @cbrewer referenced this will not check future devices automatically.
That said please check see this feature request for more information on this functionality which we plan on releasing with version 9.8: https://jamfnation.jamfsoftware.com/featureRequest.html?id=3550
Thanks for posting!
Posted on 08-24-2015 02:35 PM
Great to know. Thanks Eric!
