21 hours ago
Hello everyone!
Searched/googled but don’t find any good guide or solution for it. Anybody know anything?
We shell uninstall it from abot 1.000 Macs and replace with another anti virus tool.
21 hours ago - last edited 21 hours ago
you read this ? https://www.bitdefender.com/consumer/support/answer/1446/#accordion-1-t%60
check the uninstaller pkg. with something like Suspicious Package app. It's probably just running a script... pull / adapt that ?
19 hours ago
16 hours ago
This is the way, check for vendor documentation and use it. Most security tools are fairly simple to remove so long as you have the anti-tamper password, and every one I have seen has a silent way to remove the tool as Security Engieers want to talk to users less than we do
15 hours ago
Thanks.
