Big Sur and Monterey Printing Errors
  • June 6, 2022
  • 29 views
Hi Everyone,
Currently, I am having issues with printing to Ricoh printers in our schools with macs running on both Big Sur and Monterey. Whenever certain students or staff print, they get the following error:
ERROR : invalidfont OFFENDING COMMAND : show STACK: (!)
I have managed to find a workaround with a change to the Rasterizer in the PPD files of the print drivers, by running the below script:
#!/bin/sh cd /etc/cups/ppd find ./ -type f -exec sed -i '' -e "s/TTRasterizer: Type42/TTRasterizer: None/" {} ;
However, any mac that I run it on throws the following error:
find: -exec: no terminating ";" or "+"
If anyone has any input on this, I  would appreciate it! If you have any other questions, please let me know!
Bol
  • June 10, 2022
When connecting to these printers is there smb / ntlm / kerberos / AD authentication from clients?
There's been ongoing bux fixes for these and similar areas over the last two major macOS versions which had me re-work out print work flow in the mean time.
See here for all the details if this sounds on the right path!
https://support.apple.com/en-au/HT212586
Bol
  • June 10, 2022
Sorry I was also going to say, I remember testing a similar fix when things packed in for our printers. While I thought it helped, there was other issues at play unfortunately!
starbuck
  • October 16, 2024
I don't have a solution for the printer font error since I've been searching for it too, but the script error is solved by adding a
before the last semicolon to be:
find ./ -type f -exec sed -i '' -e "s/TTRasterizer: Type42/TTRasterizer: None/" {} \\;
