JSS9 converted each section of a smart computer group (Computer info, Location info etc.) into separate sections whitin brackets and an AND between them.
That sounds right, but it treats the AND as an OR in my case, which means that computers are attached to policies that they aren't supposed to be attached to if just one of the conditions are true.
Are others experiencing the same?
And is it only possible to add criterias to a smart group at the end now? In 8.x you could add criterias where you wanted them.
