Casper Focus numbers not correct
brandonusher
Contributor II
I have a class that has 28 devices in it from a static mobile device group.
On a teachers iPad, it shows 25 students and when refreshed jumped down to 22 students.
On my iPad, it shows 28 students consistently.
Has anyone else had this issue? If so, what did you do to solve it?
1 ACCEPTED SOLUTION
brandonusher
Contributor II
It appears the solution was to uninstall and reinstall Casper Focus on the teachers device.
1 REPLY 1
brandonusher
Contributor II
