Casper Imaging - the script could not be found
scharman
New Contributor
Hi all I am having an issue when imaging my macs, if I try a include a postflight script to call on other settings and software updates I get an error in my jamf.log saying
The script could not be found.
All other packages work fine and these scripts work fine if deployed via a policy or ran manually in the terminal.
the only information I found so far is https://jamfnation.jamfsoftware.com/article.html?id=151 which assumes theres an error with the script itself,
I'm running 9.81.
Any ideas?
41 REPLIES 41
skinford
Contributor III
@gachowski Thank you I'll look into this. Have a great day today!
dlang
New Contributor II
late post, but
you could create a package that runs a script that connects to a server share with your scripts that runs all scripts in the folder.
that way you can still manage without having to build packages every time you need to edit something,
I actually had a system that did just this. then we bought JAMF.
now I have to go back to the system I had written years ago.
security is a slide rule with utility on the other end. too much security, and your app can be rendered useless.
