Posted on
08-03-2020
08:12 AM
- last edited on
03-04-2025
02:25 AM
by
kh-richa_mig
I am trying to use AutoDMG v1.10b587 to create a Catalina 10.15.6 DMG to be used with vfuse, but I keep getting the following error:
Workflow failed: Build failed (Installation of 'InstallInfo.plist' failed with return code 1. See the log for details.)
I checked the logs, but couldn't find anything more than the error message above.
Anyone have experience with this? Or is there a different way I can create the DMG to be used with vfuse?
Thank you!
Posted on 08-03-2020 10:49 AM
Try moving the install .app to another volume OR put it into a .dmg first.
Known Issue
GitHub Isssue
