When I set in the Active Directory the User option - "User must change password on next login" - I get a strange behaviour. See GIF -> https://ibb.co/cqy3MJ
Problem:
You start the computer, click on the Username, than the prompt comes up immediately. You can not change than the password in this prompt, you first need to click "cancel" an type in your password, and after that, the prompt comes up again, but now you can change the password.
When I set:
defaults write /Library/Preferences/com.apple.loginwindow SHOWFULLNAME -bool true
I get the correct behaviour.
How I can get the correct behaviour on the User/List screen?
