Chrome CBCM - first startup policies need to be reloaded manually in order to get them work
mucgyver
New Contributor III
Hey all.
I tried to get Google Chrome CBCM running with a Config profile, and basically, it looks fine.... except that the intended settings (mainly URLs zu open at first start and set Chrome as default browser) fail to apply as soon as Chrome is auto-opened during enrollment via a script:
# Get the currently logged in user
loggedInUser=`ls -l /dev/console | cut -d " " -f 4`
echo "Current user is $loggedInUser"
sudo -u $loggedInUser open -a "Google Chrome"
EDIT: Same behaviour if Chrome is manually started by user, not via script.
However, when I check chrome://policy, all pre-defined policies from CBCM show up fine, so I would assume that they got properly loaded by Chrome before. Odd thing: When I no click on "Reload policies" in this window, close and re-open Chrome, all settings (except for wallpaper, but let's forget about this one), are now properly applied.
So, does anyone understand why this policies show no effect on first launch?
I attached some screenshots that might be helpful. Thank you all in advance.
Best regards
Chris
dd347cbc89844f85971f5483cbea539d
7002182dee504c9586b4025799378f03
df1d65a0c89a46a18bb5c76be74d3617
0 REPLIES 0
