Posted on 10-25-2013 05:31 AM
Hi All,
I want to know if any one is experiencing VPN connection problem after upgrading to Mavericks. We are using Cisco AnyConnect version 3.1.02040 and 3.1.03040.
Thank You,
ArielN
Posted on 10-25-2013 05:34 AM
I just posted a similar question, hit refresh and here yours is.
I just tried 3.1.04072 and it's got a problem with disconnecting every 50 seconds or so.
Posted on 10-25-2013 05:48 AM
I contacted Apple Server Engineer Support yesterday and they informed me that they are working with Cisco to find a solution, this is what i received from Apple Server team:. Http://supportforums.cisco.com/thread/2247235
Posted on 10-25-2013 05:51 AM
I will keep an ear to the ground in my Environment as we just rolled out build 3.1.03103 but gave my Engs a heads up
Posted on 10-25-2013 07:50 AM
This is posted in the latest AnyConnect read me (.4072):
AnyConnect may not operate reliably on Mac OS X Mavericks / 10.9, as described in defect CSCuh73010. There are intermittent disconnects with wireless connections. Wired connections may also disconnect, but not as frequently. Cisco is working with Apple to resolve this problem.
Posted on 10-25-2013 08:47 AM
I have a few testers who have Mavericks and Cisco AnyConnect 3.1.04059 and they haven't had any issues.
On a side note, we are working through some other potential issues with the AnyConnect client that is causing latency issues. So maybe there is something related.?. More specifically it's around the Web Security portion having no license or a misconfigured license. You may want to confirm this isn't causing any of the issues for you.
https://twitter.com/mattvlasach/status/256214425000890368
If you aren't using Web Security and have it installed you can run this command to uninstall.
sudo /opt/cisco/anyconnect/bin/websecurity_uninstall.sh
Posted on 10-25-2013 09:07 AM
I was able to consistently reproduce the disconnects using the GM build of Mavericks (13A598) only older MacBook Pros (2008, 2009 and Mid-2010), leading me to speculate that it was related to the chipset. I haven't had a chance to test it again on the release version of Mavericks (13A603), however.
I have yet to have a user in my environment report an issue. but expecting it.
Posted on 10-28-2013 07:33 AM
Hi All,
Here is an update to my problem with VPN connection running in Mavericks.
Apparently if i set my VPN plug-in connection to Allow to Run in Safe Mode i can connect to my work VPN.
I will make a call to Apple Server Engineer Support to find out if this is a risk to our network environment. Please let me know if any one is face with this problem after upgrading to Mavericks.
Thank You
ArielN
Posted on 11-07-2013 04:13 PM
Cisco just posted a workaround patch to use while Apple addresses the root cause in 10.9 in a later software update; probably 10.9.1 although no dev seeds have been posted for it yet.
https://supportforums.cisco.com/thread/2247235
