Cisco Anyconnect Socket filter not active on Big Sur
  • November 10, 2021
  • 37 views
I've used Cisco's documentation:
AnyConnect macOS 11 Big Sur Advisory - Cisco
and
forums:
https://community.jamf.com/t5/jamf-pro/anyconnect-socket-filter-on-big-sur/td-p/228014
for guidance but I cannot get this socket filter to work correctly. It remains inactive, hence VPN tunnel can't be established.
Here is my configuration profile that should allow it but it's not:
 What am I doing wrong?
  • November 10, 2021
 Did you approved the system extension? You need two different profiles (or one profile with two payloads) for Cisco AnyConnect. Also you need to pre-approve the system extension before you install Cisco AnyConnect.
Here we deploy two configuration profiles:
  1. System Extension (pre-approves the Cisco AnyConnect system extension)
  2. Content Filter (configures the socket to be used by the system extension)
Follow instructions here: AnyConnect macOS 11 Big Sur Advisory
Thank you for replying but it looks like you didn't see my screenshots of the payload that covers both. I also have that very link in my post.
...and yes, I'm painfully aware that the payload comes before the install. Hence my frustration with it since I have to remove the package, remove the payload and restart the machine when testing any changes to make sure the new payload is in place before I do the install.
