Hi all,
I just replicated my data over to a secondary distribution point that we
plan on using to help alleviate some of the network latency we've been
seeing from our business partners.
It appears as though everything replicated over with no issues, but after
changing the autorun data on one of my machines to use the new dist point as
its primary, when I try to load that machine using one of our compiled
configurations it fails. It tells me 'Preparing for block copy...' then
'Erasing disk Macintosh HD...' then breezes through each package/script in a
matter of 10-15 seconds and reboots to a flashing folder.
As far as I can tell, there is no way to recompile the configuration on the
secondary dist point. Does anyone else have any other suggestions?
Thanks,
Bob
