Connect to SMB - prompt for credentials with nomad
Captainamerica
Contributor II
We are using Nomad and syncing password to AD. When connect to a smb share on a fileserver (running 2008 server) a popup is appearing saying "connect" or "cancel". When clicking connect the share is loading fine
Maybe it is me, but I cannot understand why it prompts for that as the user is signed in with known ad credentials, so I would mean it just just connect right way. Do other experience the same or could it be server issue because of an older 2008 server version, that however soon should be updated.
1 REPLY 1
Chris
Valued Contributor
This should be resolved with 10.14.3 or Security Update 2019-001 respectively, is your OS up to date?
