Posted on 06-04-2020 09:22 AM
keeping getting that error but I can manually mount no problem. But for some odd reason when I use Jamf admin it's not cooperating.
Posted on 06-04-2020 06:51 PM
I get the same thing and can manually mount with no issues. Mine says opening in offline mode.. Is your dp hosted on Linux by chance? I haven’t found any help.
Posted on 06-05-2020 05:34 AM
Mac osx server.
Posted on 06-05-2020 06:00 AM
@Andrewpants1 What version of Jamf Pro, and are there any special characters in your password? There was a PI with some special characters, one of those being an exclamation point as I recall, not working in a DP password. I don't know if it's been fixed and I don't have the PI # handy to check.
Posted on 06-05-2020 06:05 AM
@sdagley I just test it again and It randomly fixed itself it is work I have no clue what made this work all of sudden but it is working.
Posted on 06-05-2020 06:41 AM
I hate it when that happens since it doesn't give you an idea what the problem was, but good to hear it's working
Posted on 12-08-2021 05:41 AM
Hello there,
sorry for bumping this old topic up, but it get the same error when using Jamf Admin 10.33.0 und 10.34.0. With Jamf Admin 10.32.2 it's all working fine. Just these newer versions come up with the error. I can manually mount the smb share. Any Ideas?
Posted on 12-08-2021 01:26 PM
@CarstenHermann You need to use the version of Jamf Admin that corresponds the version of your JSS. Mixing versions is a _bad_ idea.
Posted on 12-09-2021 01:06 AM
@sdagley I know. But what shall I do? the new version of Jamf Admin isn't working
Posted on 12-09-2021 05:21 AM
@CarstenHermann Apologies, I thought your JSS was still at 10.32.2. If your JSS is at version 10.34.0 and Jamf Admin 10.34.0 isn't working but 10.32.2 is open a support case with Jamf because you've found a regression they need to fix.
Posted on 12-22-2021 09:35 PM
Same issue starts happening here, JSS/Admin 10.33.0
Posted on 12-22-2021 11:11 PM
I got it solved by updating the OS to MacOS BigSur. Since then (yesterday) it seems to work fine again. Right now I'm using 10.34.2 and all is good.
