Posted on 02-02-2011 01:19 PM
Hello all,
Can anyone point me in the right direction to create/build a new smart group from a report?
Example: We're running CS3 on our Macs and recently distributed CS5. Some departments manually installed CS4 during the interim. I can see the CS4 machines in JAMF when I run the Application report, but I need to make a smart group (not manually) so I can exclude these machines.
Or, how do you keep track of these exceptions?
Thanks much.
Thanks,
Mark Pellecchia
Software Support Specialist
Support Services - Software Support
Office of information Technology
Princeton University
(609)258-7982
markpe at princeton.edu
Posted on 02-02-2011 01:27 PM
First, create a Licensed Software entry (Settings tab -> Licensed Software
On Wed, Feb 2, 2011 at 3:19 PM, Mark J. Pellecchia <markpe at princeton.edu>wrote:
Management). Choose to make an entry based on a template (Licensed Software
from Template) for whichever Adobe suite you need.
After doing that, go into Smart Groups and create a new group based on
Software. Choose Licensed Software, and then click the three dot icon to
grab the list of licensed software. Choose the one you want a Smart List
built on.
That should do the trick.
Steve Wood
Director of IT
swood at integer.com
T 214.758.6813 | F 214.758.6901 | C 940.312.2475
Posted on 02-03-2011 06:19 AM
Thank you very much, That's exactly what we were looking for.
- Mark
