Deploying a pkg with text file using Jamf Pro on macOS
bengold
New Contributor
Hi all,
I have a software for macOS with an installation that includes a pkg and txt file (contain arguments). Both files must be on the same folder for the installation.
After installation and giving full disk access, I used the PPPC Utility to create the profile. But how can I attach the txt file for future installations?
Or- once I installed once and created the profile, I don't need the txt file anymore?
Ben.
2 REPLIES 2
jamf-42
Valued Contributor II
using composer, put both pkg and text files into /tmp/softwarename
then run post install script... installer -pkg /tmp/softwarename/sofwarename.pkg
AJPinto
Honored Contributor III
Depends on what exactly you are doing.
  • If you are making the package yourself, just shove the .txt in the directory it needs to be within composer and build the package.
  • If its a vendor provided package, you likely need to either:
    • convert to source in composer, and add the text file and rebuild the package (this will break the signature of the package)
    • make a new package, adding the vendors package and the text file to the payload. Then use a post install script to run the vendor package (as JAMF wont run it because the .pkg is just a payload) and add whatever arguments are needed to call the text file.
