Specifically: After dragging the Mojave install.app into Jamf admin it is suppose to extact the InstallESD.dmg file into Jamf Admin. I don't see it there. Not sure why. Following the instructions from below.
Step 1: Add the .app File for macOS to Jamf Admin or Composer
Adding the .app File for macOS to Jamf Admin
Jamf Admin extracts the InstallESD.dmg file from the .app file so you can cache and install it using policies.
1. Open Jamf Admin and authenticate to the Jamf Pro server.
2. Drag the .app file to the main repository in Jamf Admin.
Jamf Admin extracts the InstallESD.dmg file, analyzes its contents, and adds it to the master distribution point and Jamf Pro.
The InstallESD.dmg file is displayed in blue text until you add it to a category.
3. Double-click the package in the main repository.
4. Click the General tab and choose a category for the package.
5. Click OK.
