Hey,
I have a Macbook Pro 2018 (T2 chip) blocked by find my mac. After enter too many times the pin it now shows "macbook disabled try again in 60 minutes. After 60 minutes shows, wrong pin, try again. I have the firmware password and was triyng to use rEFInd clicking in Option after reboot. It prompts to egi padlock. I put efi password and shows boot options. I select EFI boot to enter rEFInd but it always go back to disabled Macbook screen. I suspect the secure boot is on but i cant turn it of with efi password because cant go to comand + R option. So im stuck in a loop. Any ideas?
Thanks
