Posted on
02-24-2020
09:25 AM
- last edited on
03-04-2025
09:03 AM
by
kh-richa_mig
Does anybody have a way to look for Rapid 7 and it's version? it doesn't seem to put anything in the /Applications folder.
Solved! Go to Solution.
Posted on 02-25-2020 06:51 AM
I would probably do this
grep "Agent Info" /opt/rapid7/ir_agent/components/insight_agent/common/agent.log | tail -n1 | tr ' ' '
' | awk '/Version:/{getline; print}'
That should print out just 1.4.84
based on your example above. But you'll need to test it to see of course.
Posted on 02-25-2020 05:51 AM
this is how the rapid7 doc says to check the version number... what would be the easiest way to grab just the portion after "Version:"
Check the version number
sudo grep "Agent Info" /opt/rapid7/ir_agent/components/insight_agent/common/agent.log | tail -n1
The output should appear in the following form:
2018-03-20 18:03:02,434 [INFO] agent.agent_beacon: Agent Info -- ID: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Version: 1.4.84 (1519676870)
Posted on 02-25-2020 09:20 AM
awesome thank you @mm2270! Worked perfectly!
Posted on 04-28-2020 08:12 AM
I tried using this in EA and it doesn't seems to work but it works if i ran as a policy or root user in terminal. any idea what i'm doing wrong?
Posted on 04-30-2020 02:35 PM
echo "<result>`grep "Agent Info" /opt/rapid7/ir_agent/components/insight_agent/common/agent.log | tail -n1 | tr ' ' '
' | awk '/Version:/{getline; print}'`</result>"
Posted on 04-30-2020 06:24 PM
I have a few EAs for Rapid 7 I've put together, including my take on the client version. Hopefully they are helpful.
Rapid7 Insight IRD ClientID
# Report the version of the Rapid7 Agent if installed
# ClientIDs can be found in https://insight.rapid7.com/platform#/datacollection
if [ -e /opt/rapid7/ir_agent/ir_agent ]; then
clientID=$(grep -Eio '"Client-ID":.*?[^\]"' /opt/rapid7/ir_agent/components/bootstrap/common/bootstrap.cfg | awk -F'[/:]' '{print $2}' | sed -e 's/[{"]/''/g')
clientID="Agent Not Installed"
# Report the result to the JSS.
echo "<result>$clientID</result>"
Rapid7 Insight IRD Bootstrap Component Version
# Report the version of the Rapid7 Bootstrap Component if installed
# From Rapid7 Support:
# The agent has a bootstrap component that is running 1.2.x and this is the command and control for the agent,
# it stops and starts the agent as well as updates it. The agent itself is the 2.7.x version, which is updated
# more regularly for things like bug fixes and content patches and general improvements.
# The bootstrap gets updated too but not as often.
versionCheck=$(/opt/rapid7/ir_agent/ir_agent -version | awk '/SemanticVersion/ {print $2}' | sed s/"//g)
versionCheck="Bootstrap Component Not Installed"
echo "<result>$versionCheck</result>"
Rapid7 Insight IRD Agent Version
versionCheck=$(/opt/rapid7/ir_agent/components/insight_agent/insight_agent --version | awk '/Semantic/ {print $3}')
versionCheck="Agent Not Installed"
Rapid7 Asset Info Last Collection Time
# Report the value of the Rapid7 Agent's "asset_info_last_collection_time", which seems like a good proxy for client-to-server heartbeat
lastCollected=$(date -r $(cat /opt/rapid7/ir_agent/components/insight_agent/common/config/agent.jobs.tem_realtime.json | awk '/asset_info_last_collection_time/ {print$2}' | sed s/,//g))
lastCollected="Agent Not Installed"
echo "<result>$lastCollected</result>"
Rapid7 Remote Execution Last Collection Time
# Report the value of the Rapid7 Agent's "remote_execution_last_collection_time", which seems like a good proxy for when the client last checked for agent or metadata updates from Rapid7
lastExecuted=$(date -r $(cat /opt/rapid7/ir_agent/components/insight_agent/common/config/agent.jobs.tem_realtime.json | awk '/remote_execution_last_collection_time/ {print$2}' | sed s/,//g))
lastExecuted="Agent Not Installed"
echo "<result>$lastExecuted</result>"
jkb
Posted on 03-15-2023 02:48 PM
I just stumbled upon your Rapid7 EA's and I had to log in and say thank you. These are amazing!
Posted on 03-25-2024 12:29 PM
Your EA's are great.
Do you know how to add date format string "+%Y-%m-%d %H:%M:%S" to the date command so the date is in a more chronologically sortable string?
Posted on 06-04-2021 08:37 AM
@dmahase Your solution worked for me. Thank you.
Posted on 08-19-2024 11:31 AM
Old post, sorry. Just got R7 and was looking for EA ideas.
I was able to use a specific binary to get the agent's version (not depend on a log file entry). Example below:
#!/bin/zsh
R7_INSIGHT_AGENT="/opt/rapid7/ir_agent/components/insight_agent/insight_agent"
if [[ -e "${R7_INSIGHT_AGENT}" ]]; then
RESULT=$( ${R7_INSIGHT_AGENT} --version | awk '/Semantic/ {print $3}' )
RESULT="Missing"
echo "<result>${RESULT}</result>"
