El Capitan Developer Preview/Public Beta Build Numbers
milesleacy
Valued Contributor
Hey all,
Does anyone have a source for a list of all of the build numbers for the El Capitan Developer Preview and Public Beta releases?
I want to build a smart group to nag people to update to the final release if they are running any of these versions.
Miles
10 REPLIES 10
davidacland
Honored Contributor II
I haven't got a full list but hopefully this helps as a start:
Release 2 - 15B22c
Release 4 - 15A226f
Release 5 - 15A235d
Release 6 - 15A244d
Release 7 - 15A262e
GM - 15A282b
App store public - 15A284
scottb
Honored Contributor
Oddly, JAMF has this incorrectly stating it's the same as the GM.
See this page...
mark_buffington
Contributor II
Contributor II
The "Third Party Products" pages are maintained by the JN Community.
I edited the page to remove the "Same as GM" flag.
scottb
Honored Contributor
Thanks @mark.buffington - I saw that but didn't want to assume it was OK for me to edit...
spraguga
Contributor
@milesleacy Can you do the opposite? If running 10.11 and the build is not 15A284 then prompt to upgrade.
milesleacy
Valued Contributor
@spraguga Good idea!
Although that would work for a time, 10.11.1 may or may not be released relatively soon.
milesleacy
Valued Contributor
For anyone not sure of what we're talking about, here's a screenshot of a Smart Computer Group containing all 10.11 macs that are not running today's release...
c55873594fbb4a2e91ae1ff9ea057b0e
spraguga
Contributor
@milesleacy I guess you can make it more specific, If running OS is 10.11.0 and the build is not 15A284 then prompt to upgrade. The next release you can adjust the smart group to add the next build number with an OR.
milesleacy
Valued Contributor
There's no such thing as 10.11.0 (despite what a JSS might tell you), but your method is sound.
dmw3
Contributor III
Heres another version - Release 8 15A282a
