Posted on
10-16-2018
12:19 PM
- last edited on
03-04-2025
06:11 AM
by
kh-richa_mig
So eset has a script to install the agent which worked great. Now im getting a script error 1. I have no idea whats going on here. Im not getting alot of detail. Anyone else see this?
Sending Wake On LAN command... Opening SSH Connection to 10.10.160.21... Authenticating... Successfully authenticated. Verifying Computer's Identity... The MAC Address has been verified. Checking Operating System Version... Running Mac OS X 10.14 (18A391) Verifying /usr/local/jamf/bin/jamf... /usr/local/jamf/bin/jamf is current (10.7.1-t1536934276) Verifying /usr/sbin/jamf... /usr/sbin/jamf does not exist. Verifying /Library/Preferences/com.jamfsoftware.jamf.plist... Preparing Policy... Executing Policy 2018-10-16 at 3:16 PM | jalcorn | 1 Computer Running script Eset Agent Installer... Script exit code: 1 Script result: Error running script: return code was 1. Submitting log to https://jamf.chathamfinancial.com:8443/ Finished.
Solved! Go to Solution.
Posted on 10-18-2018 07:50 PM
You need the actual KEXT Bundles in there, try adding the following in the lower part.
com.eset.kext.esets-kac
com.eset.kext.esets-mac
com.eset.kext.esets-pfw
com.eset.kext.esets_kac
Posted on 12-18-2018 05:41 AM
@neil.martin83 Thanks for your help, esets_daemon --status gives the following:
RTPStatus=Enabled
ClientVer=6.7.500.0
AVSigsVer=18564 (20181218)
AVSigsDate=2018-12-18T13:11:10
AVSigsServer=http://um02.eset.com/eset_upd/ep6.6/
AntivirusAntispywareModVer=1546 (20181127)
Activation=Activated
AutomaticUpdateSignature=Enabled
StartupScanAfterLogon=Enabled
StartupScanAfterUpdate=Enabled
RTPEventMask=open:exec:create
RTPAdvHeuristic=Disabled
RTPAdvHeuristicExec=Enabled
RTPAdvHeuristicCreate=Enabled
ScanStatistics=Infected:0|Cleaned:0|Deleted:0
RTPStatistics=Infected:0|Cleaned:0|Deleted:0
WarningAlert=Operating system is not up to date
Posted on 12-18-2018 06:35 AM
@sdunbar In that case, my EA's should work with the following tweak to line 3 of the script on each one:
Change this:
esets_daemon="/Applications/ESET Endpoint Antivirus.app/Contents/MacOS/esets_daemon"
Into this:
esets_daemon="/Applications/ESET Endpoint Security.app/Contents/MacOS/esets_daemon"
Posted on 12-18-2018 07:02 AM
@neil.martin83 I have already done that, as that was the only obvious (to me) difference.
For for example I have
'''#!/bin/bash
if [[ -e "$esets_daemon" ]]; then
esetactstatus=$("$esets_daemon" --status | grep Activation | cut -d "=" -f 2)
echo "<result>$esetactstatus</result>"
else'''
echo "<result>Not Installed</result>"
Posted on 12-18-2018 07:11 AM
Ok - my EAs are intended to be saved from GitHub and uploaded directly into Jamf rather than copy/pasted (the script part) - as it looks like that's what you may have done, judging by the character substitution I can see with the <> symbols. The scripts should look like this:
Posted on 12-18-2018 07:48 AM
@neil.martin83 Ah, yes sorry for being a bit of a numpty!
That is all now working perfectly, thank you for all your help, very much appreciated.
