Flush All History With Problems - NOT!
donmontalvo
Esteemed Contributor III
OK, if we display policy log page with the default 100 lines, the Flush All History With Problems button appears to work.
Well...unless you expand the display to a higher number, say 2500...then it appears not to work beyond the first 100 lines.
You end up having to go into each of the red line entries and hitting Flush History for this Policy/Computer button.
Is anyone else experiencing this issue?
TIA
Don
https://donmontalvo.com
2 REPLIES 2
themacdweeb
Contributor
don, what version JSS you using?
gachowski
Valued Contributor II
I have the same issue, but I didn't worry about it sorry..
I am using 8.61
C
