Posted on 09-01-2009 08:25 AM
Our school is located next to some housing developments, and I've noticed some student computers connecting to the wireless access points located in the houses, and not getting our policies, as they are restricted to the inside network only.
Does anyone have a policy, or a package that restricts using other SSID's other than the one(s) I define?
Thanks,
Robert
Posted on 09-01-2009 08:31 AM
How are they managed? Open Directory plus Casper or just Casper? There is a setting to only allow for changes to the Airport with admin rights. If you set the SSID to yours and then enable that feature they will not be able to change it with out admin rights, and problem solved maybe.
-Tom
Posted on 09-01-2009 09:24 AM
They are managed with just Casper. Is that a Casper setting?
-Robert
