FW: system preferences not applying
Not applicable
Hi Guys,
I'm not having any luck with packaging adobe air or flash, using casper composer as well as AAMEE from adobe,
Any suggestions and or directions will be appreciated
Andrew Xenophontos
Moriah College
4 REPLIES 4
Not applicable
Hi Andrew, you can use a tool like fseventer to see all of the files that your application is installing.
Composer is not perfect at seeing all of the files that it needs to grab. (It is a great tool, but not perfect)
Mike
bentoms
Isn't "Monitor Changes" in composer fseventviewer?
Regards,
Ben.
talkingmoose
Moderator
Moderator
I believe it is.
I too have found that using Composer's "monitor system events" feature doesn't quite work well on larger installs. Maybe too much stuff happening at once. If that doesn't work the better tool to use is before and after snapshotting.
William Smith
Technical Analyst
Merrill Communications LLC
(651) 632-1492
bentoms
i think that's generally excepted as an issue/limitation with fseventviewer based solutions
