GlobalProtect users - possible problem with the 92.x releases of Chrome and Edge when VPN is active
  • August 6, 2021
  • 20 views
sdagley
There appears to be an issue with CECPQ2 and at least versions 5.2.7 and 5.2.8 of GlobalProtect. If you're getting reports of web pages not loading while a VPN connection is active with the 92.x releases of Chrome or Edge you might find deploying a Configuration Profile with an Applications & Custom Settings payload to set the CECPQ2Enabled flag to false for the com.google.Chrome and com.microsoft.Edge domains will allow the pages to load. See https://chromeenterprise.google/policies/?policy=CECPQ2Enabled and https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#cecpq2enabled for more info on how to do that.
1 reply
bwoods
  • August 10, 2021
My suggestion to you is to revert back to 5.2.4. It is the last known stable version of GP. Anything higher will cause connection issues when the machine awakes from sleep.
