Help Tinkering with Web Scraping
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 08-05-2017 12:44 PM
I'm tinkering with web scraping in bash, and I'm getting a result, but it's inelegant and, I suspect, unreliable.
What I'd love to learn how to do is to take the Xth table from a given web page, and place the contents of its rows and cells into a csv file.
Once that's done, I'd want to normalise some data, for example, dumping formatting tags, stripping 'a' tags but retaining the URL, and stripping 'img' tags but retaining the URL to the image.
I also want to do this on a clean macOS system, using only the built-in tools.
I could probably get there if I kept beating on it, but I'm reaching out to the great gestalt brain of the mighty Jamf Nation to see if anyone has already done this. Any suggestions are welcome.
Below is the example I am working with. I do not want to focus on the peculiarities of this particular web page, but rather the generic and portable approach described above.
I'm using this...
curl "https://macadmins.software" | sed -n '/Volume License/,$p' | sed -n '/<table*/,/</table>/p' | sed '/</table>/q' | awk '/Standalone|AutoUpdate/' | awk '!/OneDrive/' | awk '{gsub("<tr>|</tr>|<td align="center">|<td>|<a href=[:47]", "");print}' | awk '{gsub("</td>", ",");print}' | cut -f1 -d"'"
To get this CSV...
Word Standalone,15.36.0 [170702] 64-bit,05026bfc430e183211791b475ae48cd8c664f6b3,https://go.microsoft.com/fwlink/?linkid=525134
Excel Standalone,15.36.0 [170702] 64-bit,a352069615f65d0538c51db1cba605bd6b2d560b,https://go.microsoft.com/fwlink/?linkid=525135
PowerPoint Standalone,15.36.0 [170702] 64-bit,bf53a2e41c7f3338baa4ed5d6581b48bb1ab79f6,https://go.microsoft.com/fwlink/?linkid=525136
Outlook Standalone,15.36.0 [170702] 64-bit,c19e48d453f52e2bd3d6f7fe834a7527c7d9a64b,https://go.microsoft.com/fwlink/?linkid=525137
OneNote Standalone,15.36.0 [170702] 64-bit,421b356c19c15eb931c9aa8f8ebb8b8ae40e12df,https://go.microsoft.com/fwlink/?linkid=820886
Microsoft AutoUpdate (MAU),3.9.1 [170702] 64-bit,52f907a9c429c7fe12e4800f64e8c81241155652,https://go.microsoft.com/fwlink/?linkid=830196
From this page...
- Labels:
Scripts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-07-2017 12:54 PM
How are your RegEx chops? That's going the best way to scrape a webpage.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-07-2017 01:35 PM
@milesleacy You can try this, but beware that this is also pretty fragile since it relies on Microsoft not reformatting their table at all. As soon as it changes even a little this could break. But that would likely be true with almost any code I think. Webpage tables weren't really meant to be parsed in this way, but I understand why you're doing it. I've run into situations where sometimes its the only thing that works for the end goal.
curl -s "https://macadmins.software" | egrep "Standalone|AutoUpdate" | sed '/OneDrive/d;$d' | awk -F'>|<' '{print $5","$9","$13","$18}' | sed "s/a href=//g;s/'//g" > ~/Desktop/Office.csv
For me, this outputs a file on my Desktop that looks like this when opened in Excel:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-07-2017 04:51 PM
Thanks @mm2270 Thats a greatly simplified version of my mess, but still particular to the example html.
@Maxalot I'm decent a RegEx, and great a googling to expand my understanding.
Could you expand on your suggestion?
Ideally I want to identify whatever is within any given table, tr, and td tags, with and without parameters like align, font, etc, and dump the contents into csv.
Someone has to have cracked this proverbial nut already.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-09-2017 09:12 AM
sed 's/<[^>]*>/,/g' | tr -s ',' | sed 's/^,*//g;s/,$//g'
As I said something like the 1st regex is I think is what you're after. It's used below. Here are some other ideas:
If you are doing something like this, in my opinion, you should use
xmllint --html --xpath ...
or an xslt style sheet. Pure bash solutions will cause you to go insane.
I had to run your output through tidy to get xmllint to like it.
[http://infohound.net/tidy/]()
Once I did that, I was able to get output somewhat close to what you want with a lot less bash craziness:
$ xmllint --html --xpath "//html/body/table/*[contains(., 'Auto') or contains(., 'Standalone')]" /tmp/file.html
| grep -v '^s*$'
| sed 's/.*href="(.*)/1/;s/<[^>]*>//g;s/^[[:space:]]*//g'
Output:
Word Standalone
https://go.microsoft.com/fwlink/?linkid=525134">
Excel Standalone
https://go.microsoft.com/fwlink/?linkid=525135">
https://go.microsoft.com/fwlink/?linkid=525136">
Outlook Standalone
https://go.microsoft.com/fwlink/?linkid=525137">
OneNote Standalone
https://go.microsoft.com/fwlink/?linkid=820886">
OneDrive Standalone
17.3.6945.0724 (170727) 64-bit
efd0de7f9bd10072a27866bbcfe00b52c861c52f
https://go.microsoft.com/fwlink/?linkid=823060">
https://go.microsoft.com/fwlink/?linkid=830196">
That would be fairly easy to get into a .csv file.
I really like this tutorial on xslt:
[https://www.w3schools.com/xml/xsl_intro.asp]()
Style sheets are great because you can match them to unusual formats you may have to transform again & save them to use over & over.
To use, run a command like the following:
xsltproc -o /private/tmp/new.csv /private/tmp/style.xslt /private/tmp/file.html
where the .csv is the output file created, the .xslt is the style sheet with the transformation rules (they are not that easy to learn but powerful once you do...) & the .html is the input data.
I hope this is helpful to you & others looking to do this kind of thing.
