Help would be appreciated.
When setting up mobile device configuration profiles there is the ability to setup restrictions and within restrictions there is an app option to only display specified apps.
Is this doable via the api? I know that creating mobile device configuration profiles is possible but can you do it with implementing these restrictions?
thanks
Steven
