Help with creating a user deletion script.
monosodium
Contributor
I need to write a script that will delete all user folders except for the administrative one. I basically want to simulate DeepFreeze like things, without the hassle of DeepFreeze. My support specialist was able to come up with using "rm -rf /Users/" script at logout.
Need help with the rest. Thanks!
6 REPLIES 6
Matt
Valued Contributor
dscl . delete /Users/ACCOUNT
rm -rf /users/ACCOUNT
Heres a start
Legendary Contributor III
Is the admin account on your Macs consistent? If so, it should be easy to script grabbing all local accounts with UIDs of 501 and up and exclude your admin from it. Something like this would work-
dscl . list /Users UniqueID | awk '$2 > 500 { print $1 }' | grep -v admin
You can use the above to build a list in the script that you then run through a 'for' loop to use in a delete command.
monosodium
Contributor
@ mm2270: Yeah the name of the admin account is consistent across the board.
@Matt: Does ACCOUNT signify the account name I need to supply? Wouldn't the third line erase the admin account if that is the case?
Matt
Valued Contributor
The script is just for removing users you know of. mm2270's script will actually traverse the local directory for accounts over 501 and remove. You will need to make sure that your admin accounts are not using < 500 UID's. In our environment we give all our service accounts UID's in the 100's.
If your admin account is hidden, i.e, using a sub 501 UID, then my example will still work. In fact, you wouldn't even need to add the grep -v admin part at all. You'll end up with a list of all the user accounts that are not your local hidden admin that can then be sent into something like
for i in $userList; do
    dscl . -delete /Users/$i
    rm -rf /Users/$i
done
Just make sure you assign the $UserList variable using the first bit, as in
UserList=`dscl . list /Users UniqueID | awk '$2 > 500 { print $1 }' | grep -v admin`
Exlude the last part of "| grep -v admin" if you don't need that.
Note that I just typed that all up very quickly, so please don't just take my word that it all works. Test it out carefully.
jamf_admin
New Contributor
I have all my admins hidden and under 500 UID. Is it possible to have a script that deletes any admins over 500 without deleting any Active Directory accounts that are over 500 but could be admin or standard as well?
