High Sierra drops WiFi after roaming AP
jakobstockman
New Contributor
Beside the usual roaming problems with Mac there is now a new problem with our Macs.
When the client finally changes AP it first connects then the connection seems to come and go for a few seconds and finally it loses the connection and I have to manually connect to the WiFi again.
Tested on, MacBook Pro 13" mid 2015 running 10.13.3 and MacBook Pro 13"2016 with toutchbar running 10.13.3.
The behavior is the same when using WPA2-Personal or WPA2-Enterprise, also tried it on 3 different APs, Linksys LAPAC2600 running latest firmware.
Anyone else experiencing this issues?
Best regards,
Jakob Stockman
0 REPLIES 0
