How is Smart Group Membership evaluated?
  • September 10, 2014
  • 0 replies
  • 1 view
cdenesha
I am getting a lot of SGs that are dependent on others, or perhaps dependent on a profile being installed by others.. So when the iPad enrolls a bunch of management commands are kicked off in what appears to be arbitrary order depending on which SG criteria is evaluated first.
I'm trying to set up something complicated and I appear to be creating circular logic!! It might be helpful if I knew the evaluation order, and how nested groups plays into it.
I just searched JAMFNation but didn't find anything.
I manage iPads only.
Thank you,
chris
