I need Help : Why I am Facing a bug with Azure?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-28-2023 12:37 AM - edited 02-28-2023 08:43 PM
Hello,
I am just want to know that why I'm experiencing an issue with SSO via Azure. After configuring the connection as described here: Tutorial we have the following situation: - Logon via the "Test connection"-Button from inside the AAD Application Configuration works as expected. The user is directly signed in and reaches the JamF Pro Dashboard- - Login via Jamf Pro Login (jamfcloud.com) simply redirects to the JamF Pro Logon Page. Is there anything which needs to be done to enable JamF Pro to identify, that the user trying to connect is expected to be a SSO-User? Any hint would be warmly appreciated. PartyCityFeedback Survey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-12-2024 07:54 AM
I'd be happy to help, but I'll need more information to assist you effectively. Could you please provide details about the specific bug you're encountering with Azure? This could include:
- A description of the issue or error message you're seeing.
- The steps you've taken that led to the problem.
- Any relevant context about your Azure setup, such as the services or resources you're using.
- Any recent changes or updates you've made to your Azure environment.
With this information, I'll do my best to provide guidance on how to troubleshoot and resolve the issue you're facing with Azure. Kroger survey
