Posted on 08-17-2023 02:31 AM
Hey, I noticed that due to profile configuration I don't have ikev2 vpn profile.. is it normal that I don't see it?
Solved! Go to Solution.
Posted on 08-17-2023 02:38 AM
You should be able to display the payload switching the Config Profile to User-Level in Option > General > Level:
Posted on 08-21-2023 04:03 AM
I honestly wouldn't go the import way but rather create a new profile from scratch, uploading certs in the dedicated payload.
Less than ideal but there's some caveats when uploading an entire cert as an xml blob (when uploading non-signed profiles).
Posted on 08-17-2023 11:42 PM
oh yes indeed - thank you! I have another question because I'm migrating from jamfcloud to pro and when importing my profile from ikev2, if I change to user level and then I'll save it .. the certificate info is removed from the config and if I assign even such a profile to the user, I have n / in pending and. Do you have an idea what the problem could be?
