Hi, I'm using Composer to install the new VPN client, I go through the motions untick everything apart from VPN and then finish the installation and it launches with no issues, after I closed it and re-opened it on 4 different occassions.
We deployed VPN certificates which we tested and are working fine, on older versions and the 4.5 on the test machine.
So now the package is in Casper Admin, created a policy for it to be installed as a
Self Service method, it successfully installs the pkg but when launching the applications I keep getting different errors on various test machines.
Any ideas on this?
Thanks
