Invalid AdobeCode when trying to deploy CS4 Standard Suite
  • December 11, 2009
  • 0 views
  • 350 replies
We are running the Casper 7 suite and I am trying to set up CS4 Design
Standard (Volume License) for deployment via policy. I'm new at Casper and
think I am doing everything right.
Step 1 ­ I added the .dmg file to the Casper Server.
Step 2 ­ I told the server that it was an Adobe installer and it was
automatically indexed.
Step 3 ­ I created an Adobe installer package pointing to the .dmg. In the
options I added our license code (which I have verified as correct with a
manual install using the same .dmg).
Step 4 ­ I created a policy to deploy it to a brand new MacBook Pro
(10.6.2).
Here is where it fails. I watched on the laptop as it mounted the image and
started to install. When it went away within a minute I knew something was
wrong. Going to the status log of the policy it shows:
'Exceptions from the Adobe Installer: 17209:Exception: An invalid AdobeCode
was specified in the deployment file:'
Has anyone seen this before? I tried to search the Jamf knowledgebase with
no luck.
Thanks for any help.
Tom
Some days you're the bug,
Some days you're the windshield.
  • 350 replies
  • December 11, 2009
I did not notice anywhere to set a language.
-- Does Good Karma have a shelf life?
  • 415 replies
  • December 11, 2009
Ahhhh well thats prob it then, i had the same issue, attached is a
screen show from casper admin, as you can see I set it to en_GB, for
default it defaults to en_US, that was my issue with the very same error
you had
Criss
Criss Myers
Senior Customer Support Analyst (Mac Services)
Apple Certified Technical Coordinator v10.5
LIS Business Support Team
Library 301
University of Central Lancashire
Preston PR1 2HE
Ex 5054
01772 895054
![external image link](attachments/3bae0bfb046946249b433a5d1db4d8d3)
  • 350 replies
  • December 11, 2009
You know, I never even paid any attention to that field. I guess since I'm
in the U.S. I am just used to software defaulting to US English. Though if
the installation defaults to en_US then I shouldn't have any issues since my
media is US also. I'll have to check that setting next week when I go back
to that client.
Thanks very much for the info.
Tom
-- Political Correctness is a doctrine, fostered by a delusional, illogical
minority, and rabidly promoted by an unscrupulous mainstream media, which
holds forth the proposition that it is entirely possible to pick up a turd
by the clean end.
Cookie policy
Cookie settings
