iPad reset network settings
  • July 3, 2015
  • 13 views
Hello,
Is there any possibility to reset just network setting with the JSS ?
Just to forget, via JSS, the Wifi configured.
I don't find how to do this.
Thanks for responses.
Arnaud.
1 reply
  • July 3, 2015
It's not possible to do that via the JSS. You have to do it when you have the device in your hands
