iPadOS AirDrop management
  • July 23, 2021
  • 6 replies
  • 66 views
Hi all,
I’ve been asked to block AirDrop on some students iPads.
There’s an option in profiles in Jamf Pro that says Allow AirDrop and I restrict it. The only thing that’s happening to me is that the AirDrop function in Settings disappears and the AirDrop option in the control centre is disabled but AirDrop is still enabled.
Is there something I’m missing here? Can I enable AirDrop to Contacts Only via profile?
Thanks
  • July 23, 2021
In my testing, the restriction to disable Airdrop blocked the student's ability to send, but not to receive.
  • July 24, 2021
Hi @mmcallister,
Thanks for your reply. That’s what I found too. I had the impression that disabling AirDrop would disable all aspects of it, not just sending.
I guess it’s because Classroom and Classwork need it working.
  • July 26, 2021
Hi @mmcallister,
Hi @luispalumbo that is absolutely right.  The airdrop restriction will stop its use by students being able to send to each other, but teachers can still use it within the Classroom app to send resources to students.
dickie
  • September 16, 2021
This setting used to remove AirDrop from student iPads. Now it just seems to remove the ability for student's to change their AirDrop settings. If it was off, it stays off. If it was on for "Everyone" it stays on for "Everyone"
  • January 26, 2022
This sounds mad. Are people saying there is no way to stop a child from being AirDropped a file from someone with a non managed device (think personal iPhone)?
  • September 22, 2022
Any solution to this yet
