iPads are not syncing to jamf pro regardless its being relesed to jamfcloud server on ABM
Mshalan
New Contributor
After the authorized reseller successfully enrolled the iPads into my Apple Business Manager account, I proceeded to release them to the Jamf Pro Cloud server. However, I am currently facing an issue as the iPads are not appearing on the Jamf Pro server, indicating a synchronization problem between Apple Business Manager and Jamf Pro. I've used the same server for other iPads that were manually enrolled, and they appeared on the Jamf Cloud without any issues. Any guidance on resolving this syncing discrepancy would be greatly appreciated.
4 REPLIES 4
obi-k
Valued Contributor II
Is your ABM and Jamf Pro Prestage token synced? Can also check if those new serial numbers are checked off.
1. Devices
2. PreStage Enrollments
3. Select your PreStage
4. Click Scope
5. Search for your serial numbers and ensure they are checked
6. Wipe devices and re-enroll
Mshalan
New Contributor
i spoke to support, apparently it is required  to activate the  ipad  in order to see the device on your jamf account.
jtrant
Valued Contributor
Devices should appear in your PreStage ahead of time, but will not appear in Jamf Pro inventory until they are enrolled.
PE2000
Contributor
I have an iPad that gets the MDM profile but unable to search on Jamf Pro.
