Is it possible to package printers using Composer?
funben123
New Contributor
I have purchased Composer, but we do not own the Casper Suite. We're using OS X Server / Deploy Studio for all deployments at the moment. In previous environments where we've had Casper, I would just use Casper Admin to create printer policies. However, I'm now limited to just Composer.
Is it possible at all to package up a printer using just Composer? If I start a new and modified snapshot, then install the printer manually, will Composer reliable capture all of the changes?
If not, is there a solid alternative (other than buying Casper)?
Thanks.
6 REPLIES 6
ooshnoo
Valued Contributor
Don't think so, but try it and find out.
MattT
New Contributor III
New Contributor III
Might be cool to try packaging a printer driver with a postInstall script buried inside, using lpadmin syntax to map a printer with that driver.
jonnydford
Contributor II
Yup, we do it this way.
Capture your drivers, then have a post install script with lpadmin to add the printers.
I have moved away from this though as if a printer IP changes or we get a new one its easier to update if it's just in a script on its own.
jonnydford
Contributor II
We use the following for example. You just need to change what's after -P for the printer driver
lpadmin -p PRINTERNAME -L "label - eg 1ST FLOOR" -E -v lpd://ip.add.re.ss -P /Library/Printers/PPDs/Contents/Resources/CNPZUIRAC5235ZU.ppd.gz
Chris_Hafner
Valued Contributor III
@jonnydford Yep. I agree. It can be done but I tend to prefer using Casper Admin and or other scripts where necessary. That said, we leverage Apple software updates for driver downloads.
vstewart
New Contributor
Greetings!
I am trying to create a printer package with Composer. I'm with a university, but not with central IT, so I don't have access to Caspar Admin....I do have access to Composer 9.x. I am on OS X El Capitan 10.11.6, using the Canon ImageRunner 4051 package.
What I've done was the following:
1. Opened up the Canon driver package to install; leaving the window with the "install" button in that state.
2. Launched Composer and started a normal snapshot.
3. Click on the "Install" button to install the driver and PPD files.
4. Completed the snapshot.
5. Created a new script with the above info from jonnydford, and then complied it.
6. Once done, I then created the package.
I then tested the package. While the installer seems to work, when I went inside System Preferences, the printer was not added there.
What am I missing? Any assistance would be appreciated; thanks!
Velanche
