Posted on 03-17-2025 09:11 AM
Hi all,
We are trying to determine if we can use Jamf to audit which users are actively using Apple Intelligence.
Our hunch is that Apple doesn't log gen AI actions but I was wondering if anyone here might have some specific advice that could help.
Thanks in advance!
Posted on 03-17-2025 10:08 AM
There is no way to monitor this that I am aware of in the MDM or Security framework. There is an off chance there are console logs that you may be able to pick up with a log filter, but it’s a long shot at best.
Honestly, I am kind of curious myself now that you ask.
Posted on 03-17-2025 12:50 PM
You could try the "scream test" - disable it and see who screams.
a month ago
I'm using the EA from @dan-snelson https://snelson.us/2024/10/apple-intelligence-extension-attribute/ There's also one from @brunerd that will show if ChatGPT is enabled. https://github.com/brunerd/macAdminTools/blob/main/Jamf/EAs/OS-Apple%20Intelligence%20ChatGPT%20Stat...
3 weeks ago
@daniel_behan This is exactly what I needed. Thank you!
3 weeks ago
Thanks! We are going to give this a try.
