Posted on
05-24-2019
01:14 PM
- last edited on
03-04-2025
05:06 AM
by
kh-richa_mig
Hey guys,
we are running a jamf multi context environment.
Our production contexts are on 10.10.1 and inventory preload works great.
Yesterday we upgraded our test context to 10.12.0 and inventory preload doesn´t work.
Error message is "file extension not allowed".
The same preload csv file works in 10.10.1 without any problems.
Is this a bug in 10.12.0?
Posted on 05-25-2019 10:57 AM
I believe they changed a couple of columns since 10.10.1 you may need to download the new template and repopulate your data. Hope that helps.
Posted on 05-27-2019 10:01 AM
Tried it today on JAMF 10.12 and it works as expected. As suggested above, download the template and see if there’s any changes.
Posted on 05-27-2019 12:16 PM
@f.matheI faced the same issue and as per Jamf support, If you are using Windows edit the template and save in Mac csv format or you can edit the template the in a Mac and save it in csv then try to upload, it should work.
Or I love to do it using the uapi(Swagger UI):
1. Open the csv file you have in Notepad. CTRL+A to select all the text and copy it to clipboard.
2. Head over to https://jamfOrgUrl/uapi/doc and authenticate to generate a token.[use your jss credential]
3. Expand the inventory-preload >> POST /inventory-preload
4. Change the Parameter content type dropdown to text/csv. Note: this is not the Response content type which is irrelevant here.
5. Paste the text from Notepad into the Value field for the body and hit "Try it out!"
You should get a 201 response and the inventory preload data should be available in Jamf Pro for viewing.
Posted on 07-25-2019 07:57 AM
Running into the same issue. Tried the Mac format but nothing is working. Any new suggestions? We are on 10.13.0.
Posted on 07-29-2019 07:34 AM
Same! Doesn't work for me. Tried to save from Excel into CSV (Mac) without any luck.
This used to work great.
Posted on 08-09-2019 07:43 AM
Confirmed it working in 10.14.0!
Posted on 08-09-2019 10:26 AM
Thanks for for letting us know @jcharette, we appreciate it!
