Jamf Framework not installed DEP
KyleEricson
Valued Contributor II
Has anyone seen where the Jamf Framework doesn't get installed when a Mac is enrolled via DEP? The MDM side is all there just no ssh Jamf Framework. Could I add a quick add package in the pre-stage to fix this?
Read My Blog: https://www.ericsontech.com
7 REPLIES 7
Chris_Hafner
Valued Contributor III
I'm pretty sure I've seen it when trying to DEP via WiFi. Been a bit though.
jhalvorson
Valued Contributor
Within Settings >> Global Management >> General, do you have the following enabled:
Restrict re-enrollment to authorized users only
KyleEricson
@jhalvorson I do not have this turned on. a59fdc87d356477faf4dcb9609a19cec
Eigger
Contributor III
Usually this is just a connection issue, specially when you do it over the wifi just like what @Chris_Hafner mentioned. If I wait little while, the Binary gets downloaded or sometimes, after reboot.
KyleEricson
This is on a wired connection not WiFi.
Eigger
Contributor III
I would check the Config Profiles too that scoped to that specific machine. Maybe there are profiles thats preventing the download of the binary, perhaps like web filter agents, firewall settings, proxy settings.
KyleEricson
I don’t have any profiles scoped like that. I am doing a install of a PKG in prestage and forcing a reboot before login. I’m pretty sure this is the issue, but I want some way to fix the jamf ssh management maybe include something in my prestage PKG.
