Jamf Installation Issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on
03-18-2019
04:19 PM
- last edited on
03-04-2025
02:16 AM
by
kh-richa_mig
After going through the jamf Installation and Configuration Guide and installing everything, the last step is to connect to https://127.0.0.1:8443. However, when I do this I just get a blank white page and not the Quick Start that I should. I've stopped and restarted SQL.
What am I missing here?
- Labels:
Jamf Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 03-19-2019 05:58 AM
What is your server configuration os? ie linux flavor, windows, mac os 10.12 or 10.13?
Looking for a Jamf Managed Service Provider? Look no further than Rocketman
________________
Virtual MacAdmins Monthly Meetup - First Friday, Every Month
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 03-19-2019 06:09 AM
Since you tagged JAMF Pro Installer for Mac, I'm assuming you are installing this on a Mac?
What browser are you using? Typically, if your server is not correctly running and browser can't hit the web site, you should get an error message stating server is not available or something like that.
What happens if you type
https://<IP address JAMF Pro>:8443
from your computer?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 03-19-2019 06:21 AM
@tak10 burnnnnnn....rub it in why don't ya hahaha..... missed that
What Version of SQL are you running, do you have multiple servers? example: one for sql & one for tomcat / fileshare?
in the System Preferences Window Pane for MySQL is it Started or Stopped?
Have you tried restarting Apache/Tomcat?
sudo launchctl unload /Library/LaunchDaemons/com.jamfsoftware.tomcat.plist
sudo launchctl load /Library/LaunchDaemons/com.jamfsoftware.tomcat.plist
________________
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 03-19-2019 07:27 AM
Thanks for the quick responses all. I contacted jamf support and turns out 10.9 isn't supported on Mojave. We updated to 10.10 and everything started working immediately!
