not comfortable with scroll bar in JAMF pro 10, when you go to search inventory or when you try to add target scope...
scroll bar are not in floating or static in page when scroll need appear. Horizontal scroll bar gets appear only when you scroll until the end of the page and Vertical scroll bar gets hide under export/action banner(whatever jamf call it).. when Vertical scroll bar is visible, Horizontal will not :(
Jamf pro 10 - Scroll bar issues
