JAMF Pro API - Wallpaper base64 encoded giving an error (Problem sending command, prior command may)
  • October 12, 2023
  • 13 views
I have the following code to update wallpaper with custom base64 encoded image. I am confident this is correct, but I keep getting the error "Problem sending command, prior command may be pending, or device may not be capable."
I can't seem to find any indication what would cause this. Any thoughts or ideas would be appreciated.
$curl = curl_init(); curl_setopt_array($curl, array( CURLOPT_URL => 'https://myserver.jamfcloud.com/JSSResource/mobiledevicecommands/command', CURLOPT_RETURNTRANSFER => true, CURLOPT_ENCODING => '', CURLOPT_MAXREDIRS => 10, CURLOPT_TIMEOUT => 0, CURLOPT_FOLLOWLOCATION => true, CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1, CURLOPT_CUSTOMREQUEST => 'POST', CURLOPT_POSTFIELDS =>'<mobile_device_command> <general> <command>Wallpaper</command> <wallpaper_settings>1</wallpaper_settings> <wallpaper_content>'.$base64_encoded_wp.'</wallpaper_content> </general> <mobile_devices> <mobile_device> <id>414</id> </mobile_device> </mobile_devices> </mobile_device_command>', CURLOPT_HTTPHEADER => array( 'Accept: application/xml', 'Content-Type: application/xml', 'Authorization: Basic redacted=' ), )); $response = curl_exec($curl); curl_close($curl); echo $response;
<?xml version="1.0" encoding="UTF-8"?><mobile_device_command><uuid>f545b3503827</uuid><command>Wallpaper</command><mobile_devices><mobile_device><id>414</id><management_id>2eba7ddfe94</management_id><status>Problem sending command, prior command may be pending, or device may not be capable.</status></mobile_device></mobile_devices></mobile_device_command>
1 reply
  • November 15, 2023
Have I stumped everyone?
