JAMF Pro blocking System Preferences - MacOS Ventura
rdeleon
New Contributor III
Hello all,
Question, Has anyone come across JAMF Pro blocking some system settings options such as User Groups, Network etc? If so, how do I remove it and still have MDM installed? Once I removed JAMFcompletely from the PROFILES option in System Settings, everything comes back normally. Here's a screenshot of the block. - Thanks. Screenshot 2023-05-09 at 9.52.29 AM.png
1 ACCEPTED SOLUTION
jamf-42
Valued Contributor III
your admin on your jamf instance? check your profiles?
2 REPLIES 2
jamf-42
rdeleon
New Contributor III
That's it, I found it in profiles. It was tied to a policy that we recently deployed. Thanks for your help for pointing me in that direction.
