Jamf Pro country scoping for admins
DenisT
New Contributor
Hello
I would like to ask if there is a way to "scope" the Jamf Pro admin interface?
To give some context, we have Support teams in several countries and we will have them do basic Mac management soon. However, I would like them to be able to see only the Macs from their specific countries, and not the others.
Thanks
5 REPLIES 5
AJPinto
Esteemed Contributor
You would do this with JAMF sites, but it is probably more work then its worth.
Sites - Jamf Pro Administrator's Guide | Jamf
robjschroeder
Contributor
Hey @DenisT ! You could use an EA to determine the computer's country based on IP, or you could grab the set locale information to determine.
Country By IP (VPNs could give inaccurate results, just FYI):
# Gathers the country of the computer based on IP address
# Created 10.27.2022 @robjschroeder
jamfURL=$(defaults read /Library/Preferences/com.jamfsoftware.jamf.plist jss_url)
externalIP=$(curl -s ifconfig.me)
geoData=$(curl -s -H "User-Agent: keycdn-tools:${jamfURL}" "https://tools.keycdn.com/geo.json?host=${externalIP}" 2>&1)
if [[ $externalIP ]]; then
    # echo $geoData
    country=$(echo ${geoData} | plutil -extract "data"."geo"."country_name" raw -o - -)
    RESULT="Error - IP Address lookup failed"
if [[ ${country} ]]; then
    RESULT=${country}
echo "<result>${RESULT}</result>"
Apple Locale Information (User's could have chosen an inaccurate region during Setup Assistant, FYI):
# Determine user location based on region selected during Setup Assistant
# @robjschroeder 08.01.2023
# Gather the logged in User
loggedInUser=$( echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ && ! /loginwindow/ { print $3 }' )
# Determine locale
locale=$(defaults read /Users/$loggedInUser/Library/Preferences/.GlobalPreferences.plist AppleLocale)
echo "<result>$locale</result>"
jamf-42
Valued Contributor III
two liner.. but many ways as ever.. 😎
result=$(/usr/bin/curl ipinfo.io -s | awk '/"country": / { print $NF }' | tr -d ' ",')
Nice!
chris_kemp
Valued Contributor
I think Sites is the way to go here.
