Posted on
12-04-2019
12:01 PM
- last edited on
03-04-2025
05:48 AM
by
kh-richa_mig
Hello,
I recently migrated an employee to a new laptop. I used migration assistant to migrate the files over to the new machine. I ensured I removed all MDM profiles with the old machine to ensure certificate from the previous machine don't land on the new computer.
The new computer was DEP device so it enrolled it self before the migration started
The migration was successful however the new computer isn't taking management tasks. Check screenshot of management commands pending.
These commands have been pending for days now. Odd thing, the computer updates inventory and check in entirely fine
Here's what I tried
Command Run
sudo jamf recon
sudo jamf manage
sudo jamf policy
sudo jamf enroll -prompt (to see if the CA certificates will help)
Solved! Go to Solution.
Posted on 12-04-2019 12:11 PM
Sudo jamf removeMDMprofile
Sudo jamf removeFramework
Sudo rm /var/db.AppleSetupDone
Restart and go through setup assistant again. I did not test this.
Posted on 12-04-2019 12:02 PM
Any ideas?
Posted on 12-04-2019 01:30 PM
@zake If Larry's suggestion above doesn't work then try issuing a sudo profiles -N while logged in as the user. If it still has an mdm profile then you'll need to remove it using the command above. Using the profiles -N command ensures the machine still reports a DEP enrollment.
You may need to nuke the contents of /var/db/ConfigurationProfiles/Store/ as well as /Library/Keychains/apsd.keychain before trying another re-enrollment if the management command to remove the mdm profile doesn't work.
Posted on 07-21-2021 09:13 AM
sudo profiles -N worked like a charm. Thank you!
Posted on 09-23-2020 05:39 PM
Just ran into this. Seems to be caused by running Migration Assistant and migrating everything (rather than just migrating user account). Causes overwriting of something that breaks the configuration profile functionality. Policies would run okay after re-enrolling, but push didn't work (couldn't remove via "Remove MDM" on Jamf end either.
Had to talk customer through disabling SIP, then Bomgar'ing in and deleting /var/db/ConfigurationProfiles/Store, and reenrolling via "sudo profiles renew -type enrollment". Then customer re-enabling SIP.
Shame apple doesn't give us some possibly sledge hammer to fix this remotely. I get the point of SIP, and agree with it, but when things wedge, it's a pain in the rear.
