Jamf Pro logs to SEIM
akatsushi
New Contributor
Is it possible to push the Change Management Logs and Jamf Pro Access Logs to a SEIM like SumoLogic? We currently have a ComputerCheckIn webhook event that's set up to send data to SumoLogic but I don't see an option under the Webhook Event types for the two logs I mentioned above.
2 REPLIES 2
DBrowning
Valued Contributor II
You'd have to pay the like $20K for Premium cloud
AJPinto
Honored Contributor
If you are on JAMF Cloud, you need Premium cloud. If you are on prem you just need a tool to export the log file.
Jamf Premium Cloud | Jamf
